Double-S-Diesel
parts seller
found .100 end play in the crank on the old motor with 284k, last sunday
swapped it out for a motor with 252k
pulled the oil pan off the old motor to see which side of the thrust bearing was shot, back side was bad along with the crank, there was no wear on the front side at all, there was some wear on the main part of the bearing, but not bad.
from what I know all that would wipe out a thrust bearing is if the TC was pushing on the crank.
dropped the inspection cover and loosened the Tc bolts, the tc slides back about 1/16 so I know its not pushing on the crank
truck had a trans put in 30k ago
Im wondering if the damage was done before, or from the old trans?
should I pull the trans and look further.
should I run her till she dies again
