foresterdj
Installed my new return line kit last Sat. In the process, some fuel from old lines runs out and pools around the front and rear passenger side glow plugs. I soak up as much as I can when cleaning up, then start truck to check for leaks, giving each injector a good close look. WTH, from passenger rear there are tiny bubbles forming around threads of glow plug, same with front passenger glow plug. Obviously, compression gasses are leaking past the threads of those two glow plugs. Of course, had these been dry, with no trace of leaked diesel there to form the bubbles I would never have learned this. The other 6 glow plugs had no leaked fuel, and I did not add any to see if they had leak by also. Probably not good. On the other hand, for the last couple years the glow plug system on this truck has worked perfectly so I hate to jinx things by messing with them.
