Weird problem
promustangman
Sacramento,ca
On my toy rig my 94 powerstroke !!
Ok guys I experienced a wierd problem. /Tonight while driving home I was driving a little agressive jamming to the music not really paying attention to the tach.Well stopped at a light went to take off again I had no power only reved in gear to like 1000 rpm out of gear seemed to rev fine .Anyways drove it like this approx 1/4 mile then poppedd it in nuetral turned engine off restarted engine and seemed to run fine. Is there a rev limiter that i might have hit ??
just weird
thanks for your inputs
William
What tranny do you have in the 72 fastback?
This is a diesel forum, so if your talking about a diesel tranny, please put your truck in your signature.
Late_99_psd
Taneytown, MD
I would guess APPS (accelerator pedal position sensor), but check codes with a QUALITY scanner, the ones at AZ or Advanced arn't compatiable with rigs like ours. They may hook up and read nothings wrong, where a good scanner will tell you the problem.
You could have a soft code that wont set off the CEL, but still causes a driveability problem.
Hmmmm..... Although it could be CPS too.
m2rtin
