water pumps
War Wagon
Terry, MT
water pumps / thermostat
Any such thing as a higher flowing water pump for a 7.3L. I need to replace it along with a new radiator. It always runs hot (210 - 220 empty 70 mph). I would like to cool it down a little. Fan clutch is new and working properly.
Could my thermostat be malfunctioning? Don't know when or if it has been changed. I would thing it would either stick closed and overheat or stick open and build any heat. Anybody ever have one run hot because of a thermostat?
dsltech83
Ellery,IL
It could be if the thermostat is not the correct Ford/Motorcraft one. The aftermarkets don't cover the bypass passage completely.
dsltech83
Ellery,IL
Not sure if anyone makes one, I'd just get a Motorcraft one and stick it in there.
dyoung14
Is getting worn out
spencer,tn
Mine is an aftermarket 180 degrees and i hate it:puke: in the winter its lucky to get to 160 and thats driving forever and you freeze to death, as long as its not getting too hot then i would leave it alone a diesel likes to run warm makes them more efficient
dsltech83
Ellery,IL
Yeah factory thermostats are awesome especially in the winter, mine (heater)will run you out of the cab.
Only install the factory oem thermostat.. It starts to open at 192 degrees and is fully open at 212 degrees.... I have never seen a hi output waterpump but... Ask at an International dealer parts counter....
oldmisterbill
Grumpy Old Man
Wagoner Oklahoma
You might get lucky with an aftermarket thermostat - but it will bite your butt when you need to work the truck (like cruising at 55 :rotflmao). When towing heavy with mine it would often get almost to 220, then the Fan clutch would engage cool it and all would be fine. At first I was bothered by it but it is actually the nature of the stock fan clutch.
