Watch those air filters.
chris142
SoCal
My truck was down on power and really smoking. My restriction gauge showed a slight restriction but not pulled all the way down.
I figured I would try a new filter. Holy cow did it make a huge difference! Power up smoke gone!
Old filter only had 4000 miles on it too.
Yeah, I hear the sensors wear out. But typically they say it's more clogged than it is. (Since the spring gets weak)
Is that a stock sensor?
Could maybe go one "size" smaller.
pelky350
Springfield, OR
I've never used a air filter long enough to have one of those pressure sensors tell me my filters bad, most of what I heard Is those tend to show red when it's basically plugged solid?
chris142
SoCal
No I bought it from a local truck parts place.
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Also, watch out for the foam "pre-filter". They are pretty tight..... like tight enough to not let ether through...... yes, you read that right, and this is not an "internet legend" story..... I was running the can of "Start Ya *******"!!
I've also read several times on here that foam can cause a filter minder to pop "plugged" on a brand new filter........ my foam pre-filter has earned a nice place on a shelf.......
Cubey
Van dweller
USA
What sensor is being discussed? Must be something not on a 6.9.
chillman88
Central NY
Not so much a sensor as a little restriction gauge that goes on the air filter housing. Usually screws into that threaded port on top. Clear tube with a indicator in it that basically changes color when the filter is overly restricted.
EDIT: These
chris142
SoCal
EDIT: These
Yep. Mine was not that far down either.
Hydro-idi
Lodi, California
Those air filter sensors are damn near useless. The shop i go for oil changes to used to base air filter replacement on that sensor when I would bring my 6.7 psd in for service. The sensor read good so they wouldn’t change filter. Then one day noticed a serious lack of power. Took airfilter off and it was full of caked on dirt & oil only after 2 months use and about 8k miles.
Now I replace airfilter every month or so since truck sees dusty roads every day.
If you have the one that is 25" h2o (135501-00825), get the one that is 20" h2o. (135501-00820)
Thewespaul
Bulverde, Texas
Or just get a vacuum gauge that has the ability to remember maximum draw.
I trust that over those dinky filter minders
Figor
Illinois
What is the "go to" filter? My truck has started blowing white smoke like crazy. I'd like to start with the easy stuff first.
BrannonB
