Any articles on this subject. I would like to "turn up" the boost on my truck, I was making around 12-14 before i replaced my turbo/wastegate, i would like to turn it up to 10-12.
You need to shorten the rod on the wastegate actuator. Pull it off, drill out the dimples that keep it from turning and shorten it to where you want it. 3 or so turns is about 1psi I THINK. I think mine went in 9-11 turns to get 10-11 psi.
