paintedreams
- Joined
- Dec 26, 2005
- Posts
- 46
- Reaction score
- 0
I checked with the local ford stealership and they sail only 93 and 94 will work thanks for the offer.
Ah tink Hes speeking fer himsef.You have mentioned spell check twice. What are you getting at?
That's called "Fat Fingers"What is "yoiu"??
FWIW, I had the same problem with my CC setup (should be basically the same as yours, since my truck's an '84). It started slowly and steadily getting worse, over a period of a couple of years. Eventually, I had to keep slight pressure on the pedal at all times, but the cruise still alleviated the pressure a little bit. Then, it failed altogether. When it failed, it felt like something had physically broken...but the cable was okay.While we are on the cruise control subject mine sags bad when it gets to a hill. I have lubed the cable and have 22" of vacuum but it won't pull the throttle open quick enough. Acts like it doesn't have enough power to pull the throttle. If I help it with my foot it will hold when I let my foot pressure off. Any ideas??
