Underhood vacum
BBB
prettyprairie kansas
I am looking for a diagram or some pics of the vacum lines under the hood. From pump to cruise brakes and vacum canister etc. I have found for inside the truck hvac controls. But not the underhood stuff. Mine is missing and want to put it back like it should be
Olds64
Edmond, OK
All of the accessories under the hood use vacuum off of the vacuum pump from the vacuum manifold above the passenger's side valve cover. Hopefully your manifold isn't damaged, I don't think it's reproduced.
The only ported vacuum our trucks have is the hose from the Vacuum Regulator Valve to the vacuum modulator on the C6 transmission.
