cason234
Hello fellow IDI enthusiasts!
I have a 1990 F250 with 7.3 IDI 4x4 ZF5...... I bought it about 6 months ago, and I don't think I've posted anything about it here yet. It looks like crap outside, but I'm fiddling with it here and there to bring it up to *****. So far, lots of cleaning in the interior, new headliner, new door panels, new door handles, interior cosmetics just to make it nice to drive. Mechanically, new rear brakes / rear axle seals / new front break lines / all new fluids, etc. Just put in a new steering column (it's fixed, to replace the floppy tilt column). While I was at it, I bypassed the ignition key entirely, and now have a single switch, and a push button starter. Then, I capped it off with my little MOMO steering wheel....... This truck is a pleasure to drive! Nice and tight, with NO rattles (other than the ol' IDI thrashing away under the hood!)
Here's my challenge: the 6 months I've owned it, the voltage gauge has always been on the LOW end of its range..... the dash lights have always been fairly dim, and the interior heater fan turns relatively slowly, and the wipers are slow. HOWEVER, it always starts with no problem, and the batteries seem to function just as they should.
Recently, the voltage gauge needle started swinging WAY over to the right (high) side of the gauge. As it does so, the dash lights go full bright, the headlights are noticeably brighter, and the interior fan gains speed. It only does this when the engine is turning at cruising speed. As soon as I slow down, the gauge goes right back to the low end of things again....... And, as I accelerate, back up she goes!
Is this a voltage regulator? A bad alternator? A bad ground (I have a feeling this may be a factor, but haven't looked into it yet)? Anyone else have the same experience?
Here are a few pictures:
Here's my push button start / Momo steering wheel
