Van hydro Boost
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Anyone converted a Van to hydro boost? I dont mind the vac pump, but I would like to put an oil pump where the vac pump is.
idi_econoline
No Bed For Me!
Northern California
Went poking around RockAuto's offerings, and under E-450 with 6.0 PSD, they show a hydroboost master cylinder, Ford #4C2Z2140AA.
I might look into that myself, someday. Gotta say, I enjoy the hydroboost m/c on the 1997 Chevy Express I occasionally drive.
ifrythings
BC
Electric cruise is easy to graft onto the older trucks, uses less wires and no vac, win win, I may do a write up on this if theres enough interest.
Biggest issue I see is if the van never had hydro as a factory option you may have to make you own lines,
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Hmm. My cruise doesnt always work correctly. Say im going up a hill unloaded......the cruise will increase rpm but not enough to hold speed. If i put my foot into it i can hold the rpm.
Low or weak vacuum pump will cause that, or the vacuum (tomato can) reservoir is missing, that can is used only for cruise.
Cruise is supposed to kick out when the speed is 5 MPH below set speed, then kick down into the next gear.
