Wanderer-rrorc
the new radiator came in for the van...(http://cgi.ebay.com/ebaymotors/ws/e...0603641091&viewitem=&sspagename=STRK:MEWNX:IT) $317 for a 3 core..
so I got to work on it...pulled all the grill and such...strained so hard after it was all disconnected that Im glad Im done havin kids (darn thing must weigh 150lbs with all the scale and crap in it!! (its plugged up))
then it was time to get the old power steering pump off and the new one installed....
and broke the pivot bolt...crap...
then fought the AC brackets to get the ps pump bracket off...
then discovered 99% of my drillbits are in need of sharpening (spinning bits and makin smoke)
find a bolt
tap the hole and nothin broke
swap the pulleys..came right off..didnt wanna go back on till it broke the installer bolt..but I got it...
get the ac brackets back on...then back OFF cus the ps bracket wont go on...
fight the ps bracket... alot
put the ac bracket BACK on..
tightned all the belts..
put shroud back on..slid rad down in to see the fit..and I gotta drill the mounting holes cus the truck ones must be JUST a little diffrent (easy to fix)
started it at 4pm...at 12:15AM I closed the garage door with it not done...I have tools and grease and metal shavings all over the garage...
oh..and discovered the batteries I put in...I forgot to hook up one to the + side...and I ended up havin to lift those big suckers BACK out (31 series) to get to the rad bolts...
im tired..my hands hurt and didnt come all the way clean...
find a bolt
