They are like any other sheetmetal valve cover. Make sure the holes are not bent and if they are, lay the edge of the valve cover upside down on the edge of your workbench and hammer the holes straight. When you go to torque them put your hand over the head of the ratchet and tighten them that way. Then a couple of weeks later you can do the same again. Should be good to go after that.
