Vacuum...
Andylad13
DieselBoy
Connecticut
How much vacuum am I supposed to be getting? I'm pulling 10 inch lbs. When you hit the brakes it dumps to zero. Takes a couple of mins to build back up to 10. If I turn the truck off the vacuum stays at 10 for a while.
Andylad13
DieselBoy
Connecticut
When vacuum pumps fail, they usually fail in the VOLUME catagory first. A reduction in presure comes later. So don't just see 20-23 inches and assume it's good. It should make that presure in just a second or 3.
found it.
