Vacum Pump squeal
Spun4Fun
NC
I narrow it down to Vacuum pump area as i sprayed double squirt of WD40 and it was quite so am sure the bearing on its way out once the WD40 effect has been worn out now the chirping / squeal is back based on what i see on this link there is a retainer clip holding a sealed bearing that i could pull and replace ..!
Any one successfully done that
Macrobb
North Idaho
Also, something I learned about these vacuum pumps is that the back side of it contains oil.
Internally it's got something that looks like a cam lobe and follower - No lubrication and those parts will wear very quickly and seize solid.
So, when replacing stuff, put the new bearing in and then fill the back side of it with oil(there's a little screw on the very back of the unit).
Spun4Fun
NC
The weird thing i just noticed as i paid more attention to it is the sound goes away completely when the truck get driven for some miles
rpm427
1994 F-350 IDI
Ky.
Are you sure it's the pump?I had a similar deal and turned out to be the ribbed belt?I replaced it and noise went away
Hydro-idi
Lodi, California
Good idea to fill new vacuum pump with oil. They come with very little from the factory. STP is great for this application.
