Turbo
chrisgrant91
Nebraska
What is and where is the best way to find a turbo setup for my truck. 93 7.3 4x4 manual.... cheaper is usually always better in my case. and what is the best set up for it
85hauler
Reno
Find a truck with a turbo already on it for cheap. If you buy it cheap enough you'll be able to pull the turbo and resell the truck for nearly the same price you paid. You'll have basically a free turbo.
That's what I'm doing with the '86 F250 I have. I bought it with a Banks turbo on it for $1000. I'm pulling the turbo and The truck is nice enough that I should be able to sell it for $1000.
hesutton
The Anti-Anderson
Bowling Green, KY
Fleebay has then from time to time as well. Scout out local junkyards for older IDI's as well
Heath
chrisgrant91
Nebraska
uhm...i just talked to a guy and he has a belt driven supercharger of a 350 suburban... and aftermarket deal not a full blown intake mount setup... but what about somthing like that?
chrisgrant91
Nebraska
yeah...i thought it woudl be cool....but i dont want to screw somthing up...but it wouldnt be that tuff to do... idk basicly just make sure it doesnt overboost right?...but what i was also thinking would it even boost at the low rpms of a diesel.. what can my stock 7.3 handle for boost?
FordGuy100
Silverton, OR
You could probably make it work ;Sweet. But it is going to take some horsepower to turn that thing to make boost, more so than a turbo. So in the long run, I believe that you will see less horsepower than you would from a turbo. Plus you might not see much boost until higher rpm's :dunno
Cincinnati Guy
Cincinnati, Ohio
I was just on Ebay and there are two different turbos listed, one a Ford turbo and a Hypermax, I just yped in IDI turbo.
Fordsandguns
Fords Rule
Eastland Tx
I'd try the sc if you can get it cheap. Who knows, it might work good. Probably have to find the correct pulley to make the boost lower for the diesel. Yeah it will take more power to turn than a turbo but you never know until you try.
