Okay, taking it apart to redo the valve cover gasket. I'm seeing quite a bit of oil on the wheel and in the cdr plumbing. How much, if any is normal?
Many thanks.
Many thanks.
Ah! That helps, thanks.Intake tube, air box turbo anywhere really and I’ve always ran the truck with everything hooked up and taken the oil fill cap off, if there is blowby coming out but it goes away if you rev the engine then your cdr is fine.
