Diesel JD
Banks numbers may be inflated. Argve had the Banks Sidewinder system and the 7.3 IH IDI. He made 387-388 lbs-ft of torque at the wheels, and 201HP. It would have been more at the crank, but I doubt 270 HP, maybe...you lose a lot through that E40D. As far as your cruising s RPM, what gear ratio do you have? 9" Ford could come witha lot of ratios. Also what transmission do you have? For the IH scout, I think you'll need to dump the Ford adapter plate and the motor should bolt directly up to an SAE#3 bellhousing, but I may be off base here. If you want more info about gear ratio and RPM, look at randy's ring and pinion calculator here www.ring-pinion.com this will give you at least an idea. As for teh PSD, as icanfixall said, you'd have a much easier time with a Banks or Hypermax or ATS unit which is a bolt on affair, but the Hypermax starts at 1450 and up, the ATS around 2000 and the Banks around 2700. There was a user by the name of Woodie, I don't remember if he has an account hear or only over at the Diesel Stop, but he fabricated a PSD turbo to the IDI and was very happy with the results. His boost numbers were sustainable with the IDI in stockish trim. You might want to do some digging over there, or here about his rig. Fuel mileage, in an F-250, you can figure on 10-16mpg with 4.10s, 13-19 with 3.55s, and 20+ with 3.08s, this assumes good fuela nd ideal conditions, light loads. You can add a few MPG with a scout as it is a lighter vehicle. It sounds like a cool project. If you get an IDI motor for this swap, be sure to look it over good, change teh head gaskets and oil cooler orings before it goes in the truck. I'd hate to see you do all that work to not be able to drive it right away. Good luck,
J.D.
J.D.
