TSB90167? with pics
Is this the clutch/firewall TSB your asking about John?
John Haggerty
Birth Certificate
New Windsor, MD
Mel,
I think so. I read somewhere about a beefing up of the firewall at the clutch area. I'm curious if I already have it, or should be considering getting it done.
John
94f450sd
somewhere,ma
in your first picture that is the brake booster.look to the right of that and you will see the clutch master cylinder.if you had the TSB done you will see a steel plate bolted to it
I have it on the Moose Truck. I'll have to take a picture of it some time.
crispy74
