id_bowhunter
84 ford w 6.9.... I am banging my head against the driveway I have used clear hose from tank to lift pump, lift to filter, filter to ip, and return back to tank. Very minimal bubbles in size and consistency questioned lift pump pressure for $30 I figured wth change it. Here is the problem even with new lift pump idles ok at high rpm after 30-60 seconds it jumps to higher rpms and starts acting like there is no fuel drop it back to idle and it surges a few times and levels out or dies not sure what fuel pressure is thanks to small a** shcrader tanks are over half full my front tank has the usual problem with the pickup tube all injectors are working i did the crack the cap test I'm new to diesel motors any help would be great thanks
