goatwrangler
hey all,
My truck wont start. 1984 F250 6.9l Automatic. I have bypassed my water seperator mounted on the firewall. I have changed the orings and return lines for the injectors also. When depressing the schrader valve while cranking I only have a little bit of fuel come out. The fuel filter is fuel of ATF. I even checked twice, by taking it off and making sure it was full. I tried starting the truck afterwards and she started but didnt run long. I loosened the supply line from the lift pump to the filter head and have fuel coming out when cranking but very litte fuel out of the schrader valve unless I crack a supply line loose then the air pushes the fuel out. Maybe my fuel filter is blocked ?
I hope this makes sense ?
