Solenoid for shift interlock has failed. Disconnect it, remove it, and replace fuse, then you'll be able to move your truck again. But that also means you'll be able to put it in gear even without it running now.
I found the issue. Its actually a recall. My truck master cylinder almost caught fire. The recall is still active. I advise anyone with these trucks to get it services asap. Recall # 09S09
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
