Well... Ita shorter than a crew cab .... My guess is the same length of any single cab without an after market bumper added on. What would you be-worken-on????? Somebody wants to know....
Sounds about right. When I had my first addition built, I told my builder the truck HAD to fit. He had designed the addition to be 20' X 30' (outside dimensions), and the 20' side was where the truck was going. He measured the truck (which has a push bar), and decided to add 3" to the measurement. Good thing. I have to use an optical device to detect when I am in all the way, and if I don't stop within an inch of that, I'll bump the styrofoam sheet glued to the wall.
I have to use a hanging tennisball to get the Lariat squeezed in the garage just right. I remember the first time I had pulled out of the garage and was all set to use it driving back in, but my cousin came by with a stick and swung at it like a inverted Tball.
