Truck down TTB axle shaft needed
NTOLERANCE
I'm the cotton swab
cottage grove, wi
My dad's 1992 f250 broke the left side axle shaft
He needs the inner and the outer shafts for the TTB
ASAP who can help
jhenegh
Truck Still Earns its Keep
Deerfield, WI
I scrapped some at Easter. Darn
I think laserjock is scrapping a D50 if I read his thread correctly.
These axles arent worth much and D60s are replacing them frequently. Used cheap parts should be around. Good luck!
I've got one. Getting to it would be the hard part. It's currently stuck under my parts truck. I suspect shipping would be pricey to WI. There has got to be one much closer. Is that the driver side you need?
NJGearhead666
New Jersey
I have the driver and pass one with brand new splicer u joints in them. put a D60 in instead of fixing the D50 when I broke a shaft. But I don't know what shipping would be.
NTOLERANCE
I'm the cotton swab
cottage grove, wi
Yes I do need the drivers side. I think that rolling it up an a sheet of card board and taping the crap out of the ends would suffice.
leojr
Denton, TX
I've got a passenger side shaft (and the rest of a D50 I just removed) in Texas and can pull it and pack it tomorrow and have it heading your way Monday. If you give me your zip code I'll get the approximate freight to you. It may take 4 or 5 days unless you want to pay crazy shipping cots. I suspect the freight will be around $50. After you get the truck running you can pay me whatever you feel the parts are worth.
Where is it going to? Sorry Tapatalk won't show me where you are. I was figuring $40-50 plus shipping depending on how hard it was to get it apart.
Mine will be rusty. Leo's will probably be cleaner. Let me know tonight if you want to proceed, I'll dig into it in the morning.
leojr
Denton, TX
It's 3 pieces, the inner and outer couple/slid together and then the spindle shaft. I'm thinking $100 plus shipping, just the spindle shaft is almost $300 new.
Edited: I was looking at the right side which is 4 pieces. The left side comes out comparatively easy with just the spindle needing to come off. These have been sitting outside for a few weeks and I'm moving them up to storage in the morning.
It finally slacked off raining. If this is what you need and are interested pm me.
Jimacho
