mikeniowa
In process of removing IP as per helpful article by Mel.
Encountered many minor problems, < it's a van> . I found I had a major hangup.
I cannot raise the pump flange end up because top stud overhangs pump housing and flange..can't raise pump rear end because VAN cowl
will not allow enough clearance for fuel lines to pass over air intake bell.
What would you suggest? I'm thinking of pulling the intake manifold; but I'm so close!..........Mike
