Badassford23
Hey guy just have a couple ? About a t19. I found one for 200 dollars is there away to check to see if it work and it has the transfer case to bw 1356 is that a good deal or what thanks for the info
f250 1356's don't have the PTO port.If the tag is gone, look at rear of the T-case. If it has a bolt on rear cone and a slip yolk or if it's got a PTO port, its a 1356. If the rear is cast as part of the T-case and there is a u-joint yoke held on with a large nut, it's a 1345.
Heath
