flatlander
plays dirty when losing
I bought a book on the C6. So far I have:
tried to adjust the band. No go. It was as tight as I dared.
I hooked up a pressure gauge to the test port. 0 psi in rev., neu, and drive.
I pulled the pan. The bottom of the pan had some gunk but not an abundance. The filter was clean.
I did notice, though that the pan was somewhat dented in and the filter opening left a clean impression on the bottom of the pan as if the pan was pressed into the bottom of the filter. Do you suppose it restricted flow enough to cause problems?
I have a feeling it's all coming out.
