Matrix37495
The Amish Wolfman
Coming up soon i'm going to be swapping engines and rebuilding my transmission. However, I'm not sure where to get parts and I haven't actually done this before.
So the questions are as follows:
Where is a good place to get a T-19 rebuild kit? I know i need bearings.
Where could I find a manual to get me started on the right path?
Other questions:
When i put the 6.9L flywheel on the 7.3L I'm dropping in, do I need to swap the harmonic balancer as well?
Since I'm starting with the engine on the floor, what seals should I replace? I was thinking rear main, valley pan (needs one anyway), and maybe oil cooler (Are the o-rings dealer only?)...
If I need a complete clutch kit, where is a good place to get one, and what brands should i look for? Also, at what thickness should i replace the clutch disk? The throw-out bearing has been making noise for some time so it's getting replaced no matter what...
Are there any other tips or things i'm missing?
Thanks in advance.
Other questions:
Thanks in advance.
