Jul 31, 2008 #16 h2odrx Anti-O Joined Dec 11, 2005 Posts 4,835 Reaction score 3 Location Coastal Neckville, NC Ok thanks, so a small plate to stop leaks?
Jul 31, 2008 #17 trackspeeder Stone crusher. Joined Dec 21, 2003 Posts 4,091 Reaction score 232 Location North Branford. CT h2odrx said: So take the U-joint off, then pull the shaft out, replace the seal, O-ring and Gasket? Click to expand... Drop the drive shaft. Remove old seal.Replace with new seal. Good to go. E4OD seals do have a drain hole. It faces down.
