gandalf
Senior Member
We took the truck over to Santa Cruz yesterday to test the new transmission cooler, and to go to the beach.
The results were every bit as good as I had hoped. On the same run, with the OEM setup from Ford, I got trans temps of 220*F. The probe is in the port in the pan.
Yesterday the temps maxed out at 165*, with the new cooler. The cooler is a Tru-Cool Max 4739, bought from Bob Riley at Dieselsite. During the installation I changed the pan, filter, and the fluid.
Bob Riley's Dieselsite
The cooler is mounted in front of the radiator, in front of everything else there. I wanted it there rather than underneith in order to avoid as much road crap as possible. Bugs will be problem enough. I don't need road crud too.
Even my wife was happy with the result, said the money was well spent.
