Transfer Case Lube (1988)
HammerDown
Glenolden Pa
Time to change out the transfer Case lube on my 1988 F250.
Refresh my memory, I believe it's also what my C6 Transmission takes Mercon/Dexron-3 ... correct and approx capacity?
(not interested in synthetics)
I'll also be dropping the transmission-pan to replace the filter.
Thanks for the feedback.
rreegg
IDI n TDI
Puget Sound
Didn't know there's a filter for the tcase - is it a metal mesh or similar?
Here's another oilburner thread on the same topic for precedence, am assuming the 89 and 88 have the same tcase
HammerDown
Glenolden Pa
I'm dropping the "transmission pan" to replace the transmission filter.
HammerDown
Glenolden Pa
Found this... and I believe it takes 2-qts ???
"****For the 1980 to 1987 model years, Ford recommended Dexron II Automatic Transmission Fluid (ATF) for 4x4 Transfer Cases. Dexron II was replaced by Dexron III. For the 1987-1996 (Bronco, F150 and 1988-1997 (F250, F350) model years, Ford originally specified Mercon. Mercon has now been superseded by Mercon V which is NOT recommended for use in 4x4 transfer cases. Both Dexron II/Dexron III and Mercon fluid are listed in Ford Shop Manuals as meeting the same Ford specification XT-2-QDX. Until mid-2018".
u2slow
bilge rat
Coastal BC
The mercon tidbit is funny because mercon 5 made mercon 4 obsolete/unavailable.
The main thing is the viscosity, since these tcases have an oil pump. Any atf or similar weight hydraulic oil, compressor oil, or engine oil I expect to work equally well.
ROCK HARVEY
Dayton OH
I used mercon LV (not mercon V) in my 1356. They had it on the shelf at oreilly’s.
MtnHaul
California
I have spent some time on this specific fluid issue. Ford currently specs Mercon LV. Ford hasn't licensed Mercon since about 2006 so any ATF that lists Mercon compatible is just an empty statement from the brand and no relation to Ford. Mercon LV specs, https://www.fcsdchemicalsandlubricants.com/additionalinfo/Product Data Sheet MERCON LV.pdf
Royal Purple, Amsoil OE Fuel Efficient(Blue cap on bottle), and Redline D6 all have similar viscosity to Mercon LV. That said, Redline specs their D4 for the 1356 and when I e-mailed them about this they said yes the D6 would work but that the D4 also would be fine. I had run Royal Purple and now have Amsoil OE Fuel Efficient and no problems noticed so far, 383k on t-case. If you want to spend too much time on this just go read about ATF on BobIsTheOilGuy
sramasya
