eastsideauto
With a lift is it better to get a drop bracket for the track bar or get an adjustable track bar or both?
3. Adjustable track bar with drop bracket and drop pitman arm
^ THis. You may have to adjust your track bar bracket height. Get an angle finder and make sure the angles of track bar and drag link match. Then adjust the track bar length until axle is centered under the frame.
IIRC the F-Superdutys have a trackbar mount that goes from the passenger leaf spring plate...the other end is on the left side of the engine cross member. I was looking at adapting this to my truck but not 100% sure about pinion clearance.
Coincidentally, I was able to verify that older F-Superduties do in fact have reinforced shock towers in the 2-bolt mounting style that your truck uses.
