towing a fithwheel
jeffgordon24
91 f250 kingcab 4*4
im going to be towing my fithwheel tomorrow about 200 miles . it weighs about 7500lbs dry my truck is a 91 f250 with a 7.3 lt n/a 4*4 and has a 4aod trans . towing at 55mph at 2000rpm with o/d off would it hurt my motor much
im not worried about the fuel comsumption too much ,caus i find in o/d it keeps going in and out at 60 mph havent tried going faster though
Michael Fowler
Bel Air, MD
You are good to go.
However, some fivers sit WAY high in the air stream. It takes a LOT of HP to move all that air. You should be fine at 55, but speed up to 65 to so, and watch the engine temp rise.
Russ
Idont do injectors
New Brighton PA
Don't be afraid to go into OD if towing on flat ground, and the tranny is not "hunting" between OD and drive. When it starts hunting for Drive just push the button and stay in drive.
Ironman03R
Risingsun, OH (NW OH)
Get some gauges if you dont allready have them, Trans, Water, EGT. Just keep and eye on them so you dont cook anything.
Just my .02
+1 on the cooler. I think if Ford had OEM'ed these with a BIG cooler on them, the E4OD would have a much better reputation.
ntjapkes
