torque cam
pennsylvaniabo
pennsylvania
Those of you running this cam.....does it make a seat of the pants difference? If im gonna pull the motor to do gaskets and studs, might as well do this if it is worth it.
oldblue05
PIN IT TO WIN IT!!!
Caldwell, Tx
fwiw I'll be wanting one in a few months... but right now I'm more focused on my 4wd conversion.
Read my sig then ask Towkat
When they did this cam it was the same grind that was put on the GM 6.2/6.5 cam, it was dynoed to an 11% increase in HP and TQ, We figured it should be the same on our IDI's. Thats why I want some serious before and after pulls.
Definitely interested if I can get a good core in time.
I have a few cores to cover for a while so it isnt a huge deal just want to get it back asap.
I also have reground fuel pump lobes for them also. I think they charge 15.00 for them
lindstromjd
Black Sheep
West Des Moines, IA
Put me on the list for wanting one then. How do you do payments for these?
And what does the reground fuel pump lobe do? I assume it's to increase fuel flow from the pump, but can you explain it better?
Fuel pump lobes get worn these are welded up and reground, has nothing to do with more flow, just no wear.
hawaiian808
Whiplash FTW
Mifflinburg PA
Well then I shall wait then because someone might need it before me and I don't wanna hold anyone up by reserving anything
Dont worry about that, my buddy just brought by 3 more cores.
Diesile
Smalltown, Ma.
Russ I'm in for one. That's $189 + $15 for the pump cam and shipping is?
Check or mo will be in Monday's mail.
Thanks, Lorin
shipping is about 12, itl be close enough.
dented73
