I change the fuel filter out every other oil change and I just had it changed again thinking that it may have been the cause. The fuel looked real good and the housing as well, the color looked like normal diesel fuel (clear with no darkness from oil). I did have to replace the lever and oring assembly for the fuel housing drain due to the valve not wanting to close after being opened and closed a few times in a row. Still no luck..
The weird thing is that after the truck has sat for a few days, it will turn over like I said and I then have to pump the peddel and bang!!! Engine fires up and revs high like it is clearing exess fuel.. I know that you should never have to give a fuel injected vehicle any throttle when starting, but it just continues to turn over until I pump the throttle.
Again, as long as I start the truck ever day and let it warm up, I have no starting issues as all. It fires right up without touching the throttle.
I am new at working on PSD as I have always taken it to someone and just trying to gain some knowledge from all of you with regard to a PSD.
Thanks again for all the help.
