Tool for cutting open oil filters?
DOE-SST
1994 E350
USA
Homemade or store bought...
What cha got?;Really
Where'd you get it?;Really
What'd it cost?;Really
How do you like it?;Really
87crewdually
Southern Nj.
Exhaust pipe chain cutter works the best. No dust or metal shavings and it's fast.
DOE-SST
1994 E350
USA
tin snips ought work :D
only if they come with a first-aid kit:rotflmao
I can only find chain-type pipe cutters that go to 3.5 inches, and my oil filters are 4" O.D. I could modify them, but I'd rather find a better tool. Ebay has heavy-duty cutters, but they start at $70 and go up to $300, not including shipping.
subway
be nice to the admin :D
York PA
that’s what i used but i had trouble with the cutters breaking through in one area faster that the other. then they got REAL hard to turn. might just be my technique though.
i did see a set up in jegs for 40, looked like a drill press clamp with 3 cutters to get around the diameter.
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Is there such thing as a large tubing cutter. What I am thinking about the the little cutter you use with copper tubing. With a cutter wheel, and a bearing and spin around the tube, tighten a bit, and repeat. Do they make a large version of this?
MidnightBlade
Shiftin' Smooth
Johnstown, PA
id remove the whole assembly and cut it with a grinder the wipe it clean and wash it, wait we are talking about the soup bowl right?
Cv axle
