smokin69
Always smokin'
My friend at school has a 89 F250 with a 7.3 and zf5 and we where messing with it and decided to turn his pump down, as it was maxed out and had some non-stock parts, dumping lots of fuel in from when you put your foot to the floor to redline, and never cleared up. Before he would run around 1250-1300 on the egt's going up a 6-7 mile hill. After we turned his fuel down he pulled it again and hit 1800 from about a half mile up and by 3 miles into it the pyro was burried. I know this isn't good for it but he doesn't care about the truck as he pulled it out of a farmers field for 300 bucks and just does whats neccasary to keep it running. Anyway, I was wondering if you put too much fuel into an engine if it can end up actually cooling down the egt's because there is so much unburnt fuel and it's running so rich that it can't burn hot enough?
