Goofyexponent
Mentally Unstable..
I remember reading a while back about timing adjustment. I am interested in advancing my truck a TOUCH to see if it helps me start on really cold mornings. The timing advance IS workin on the pump. I checked this while changing a couple glow plugs today. I feel that it is not advanced enough to start on cold mornings.
I read that I should mark the position of the pump in relation to the timing cover before I do any adjusting so I can return it to where it was before I started.
IIRC all I do is take my "modified" wrench, or the wrench set I bought with the specific use of adjusting my timing. Loosen up the 3 bolts that hold the pump to the timing cover and move it about the width of a dime towards the passenger side fender. Tighten the bolts up and run the truck, look for smoke and listen for noises. All of this done with the engine up to operating temperature?
Worse that can happen is that I set it back to the mark I made with the punch and take it to a shop to get her timed up.
This spring, she WILL be getting a new pump and injectors. I am just trying to baby it through the lay off season until the $$ comes washing back in.
