Well, yeah its true. The $77.50 7.3 motor I bought has a rod broken. I pulled the heads and found water in every cylinder because the injectors had been pulled. I was able to break it loose and start turning it thru till it stopped. I noticed cylinder 5 piston not moving. So off came the pan. While I was pulling the pan I saw a very tiny hole at the pan rail that had been "fixed" with some hammer work. Something you would have needed to scrape the dirt off of. I asked the owner why he pulled this motor. He said "because it had many miles on it." Damn liar..... Well enough for the bad news. The motor ran for some time but no real damage anywhere. The crank is fine, the bottom of the sleeve skirt is slightly chipped and an oil squirter is bent. So other than a bent rod and a broken rod all seems fine for a many miles motor. The rods were worn thru to the copper and it had a gasser thermostat in it. The cooling system was not kept up. No anti freeze was found in the motor. The small amount of water in the pan was probably rain water leaking past the rings. Only one intake port in the drivers side head on number 6 had water in it. All in all I couldn't have paid $77.50 for the parts alone. I will have the bolck pressure tested before I sleeve it or do any work on it. I have been looking for a rod cap because I bought a turbo rod set on Ebay some time back but 1 rod cap was missing so I needed 1 for a complete core set. Now I have that rod cap and I can turn this used set in and get another rebuilt set while Ford still has them. I can never have too many spare parts I guess.
