Throw out loose on shaft
85rollback
North Carolina
Installing the LUK clutch assy for the swap of a ZF5 where a four speed was. 1986 6.9. The new throw put bearing (INA brand) is a verrrry loose fit on the shaft it slides on. I'm talking .025 difference in diameters. Is this OK? Will it just center itself when I push in the clutch?
I believe its centered by the release fork. That amount of play doesnt seem unusual to me.
85rollback
North Carolina
I found the correct part FB-01747-CA or FB01747CA. Slightly smaller in diameter than the one in the LUK 07-225 clutch/flywheel kit.
