lgettler
Which way do I turn the TPS sensor to lower it from 1.1 to .95 or thereabouts, I am looking for a smoother shift as it pops my head if I stomp on it.
I know exactly what you're talking about, I had the same issue with my truck - I have the regular Transgo kit with a .427 modulator valve and forgot what else separate add-on, and my shifts still took forever to complete - what I did to deal with it is drop all the VB pieces again, and then drill out the holes in the separator plate that feed the accumulators - faster accumulator fill makes for faster shifts, it also firms them up a bit too (but not too much). Also, my take on the TransCommand - it's just snake oil, I've looked at its installation manual and all it does is jack up the line pressure, it's supposed to be driveline-load-sensitive but I fail to see how it accomplishes that when it only intercepts the EPC voltages and has absolutely no input from the shift solenoids - how can it determine the load on the driveline if it don't even know which gear the trans is in? There's a good reason why the factory PCM has so many inputs, granted it probably don't need every single one of them but still there's a bare minimum to make things work right, and the TransCommand inputs are well below that limit. You can achieve the same results with a variable resistor if you so wish, I had a few quick-change power resistors in my harness, and when I finally drilled the separator plate I tossed all of them out and never looked back.i think thats what i will do because the shifts are so slow that when accelerating hard the acceleration actually stops while the trans is deciding to shift. is there a minimum voltage for the FIPL setting? if so there must also be a max so what is the range that the voltage can be set to?
That's about as low as you can go actually, so your hands are tied in that department. Even if that were not the case, the issue you're describing would be actually made worse if you turned the FIPL voltage down. IIRC your idle FIPL reading should be between 1.0V and 1.1V, and your WOT readings should be between 3.8V and 4.3V - basically you set your idle voltage, and leave the WOT fall where it may, just as long as it's withing the proper range. The reason for the wider WOT range is that not all IPs have the same throttle arm travel, as in some can turn more than others, resulting in a higher WOT reading even tho the idle one is the same.i have a reading of .99vdc right now and i didn't change it because i didn't know how low i could go.
