Theories....
opusd2
BFE, WI
Just my 2 cents here...
In all my vehicles, I run multiple batteries in parallel. To them I keep a Shumacher trickle charger installed in the vehicle, attached to both batteries. Here is the charger:
http://store.schumachermart.com/se-1-12s.html
It works very well and can be run for extended periods. I often just use it in winter to warm up the batteries before starting. It works well.
Now I own one of those Battery Tender Plus's that everyone here is talking about. I keep it attached to my Harley over the winter months and sometimes in between rides during the riding season. My stock battery is now 8+ years old and you'd swear it was new by the way it checks out. I also use it on my larger vehicle batteries when their charge is down, or to refresh the insides of my batteries. I have Dual Optimas in all my vehicles and the oldest set is 7 years old and is fresh as a new set. Then again, I will routinely throw the Battery Tender on a battery every so often wish excellent results. I couldn't ask for a better combination.
However, a Battery Tender will not charge a completely dead battery. I once had a small drain that I didn't notice on a single battery application with an Optima, and it went dead. None of the electronic chargers I had would touch it saying it was damaged beyond repair and needed replacing. So I snapped on an older solid state charger I had until it had a small amount of charge in it. Then the Battery Tender Plus went on it for a weekend and it was charged, but I let it go for a week. Then I disconnected the chargers and let the battery sit. A few days later it still tested well. So, I am sold on those Battery Tenders for refreshing the innards of the batteries I use.
But for everyday use I like my Schumachers installed in the engine compartment connected to both batteries in parallel. It works for me, and that's all I'm saying.
Well I did end up getting a second new battery from Napa. So, I had 2 new batteries and decided to put them in the Scarlet Moose, since I actually had the short fat batteries that really belong in an 87 and up in there. So now I have good group 31's in the Moose truck. These Napa's in the Scarlet Moose, and the Moose Truck and Lady Moose are running on identical battery tenders. If the desulfator is a problem, then I should continue to see battery tenders burn up on the Moose Truck, but not on the Lady Moose. Time will tell.
MIDNIGHT RIDER
Have any of you tried taking a 10 amp or so charger and connecting the positive lead in series with an 1156 light bulb and then to the batteries ?
That concept is a first for me.
Let's see if I get the hook-up right; Positive lead of charger connected to the Positive terminal of the 1156 bulb; then, a wire from Negative of bulb to HOT post of battery; charger Ground connected to battery Ground; right ??
Although I have bunches of the little H-F tenders, I may just experiment with this idea for the fun of it. ;Really
