Testing 4x4
rreegg
IDI n TDI
Puget Sound
thanks for all the input. Everything I’ve done suggests 4x4 does not work.
Dropped the clutch on gravel - only rear tire marks. Dry road turns with 4H feel the same as 2H. Did some tests with snow cover the other day with same results. Oh well put it on my tab.
I’ve verified the hubs were locked too
Weird. Wonder if the shift fork isnt working right. Lo range is just a planetary gear reductor so that may be why lo feels like it works... But still no power to the front wheels.
Cant Write
Placerville CO
I agree with Nero, can you get someone to help and look at the linkage while they shift it in 4-hi.
Should be able to do it with the engine off, in neutral and use body weight to rock it. Slight incline can help.
Then if it isn’t engaging, try manually engaging it under the pickup to find where the problem lies.
I bet it’s the linkage.
Clb
Another old truck
nannyfornia
Are the hubs blown?
These t case shifters leave ALOT to be desired.....
Or leave hubs in free position, put t case in 4 hi or 4 lo, then try to turn front driveline by hand. Make sure transmission is in gear. It shouldnt move if all is good.
MtnHaul
California
Not to get too far off-topic but folks really ought to educate themselves about Soviet Communism and the Stalinist dictatorship that followed before comparing it to anything else--Stalin also purged the government and military of anyone who might be less than blindly obedient or dare to stand in his way. History doesn't repeat itself but it does rhyme.
Clb
Another old truck
nannyfornia
Blanket term used by us cold war era boomers.....
******,socialist, reformist ,revisionist, are all the same.
I'm not going to start a shitstorm for the mods to deal with here so I will take down the offending file:sucks
Don't take it so hard Alice...
Another boomer thing;Poke
Fwiw my grandmother was in country before Mousilini (?sp?) Met ******,( woke alert h i t l e r )
she said he was a good man till then.
david85
Campbell River, B.C.
Dry road - put it in 4-hi - turn hard right/left -- if it bucks, grabs, jerks while going forward in the turn -- it's workin'
Yup, this right here. Just don't do it if loaded heavy because this puts strain on the axles.
rreegg
IDI n TDI
Puget Sound
Verified the tcase shifts when actuated by lever. It appears the front driveshaft will turn with tcase in 4Hi and hubs Free, trans in gear. Front driveshaft does not spin with tcase in 4Hi, hubs locked, and trans in gear
Clb
Another old truck
nannyfornia
Interesting
So try stopping the front driveshaft from spinning CAREFULLY while in gear hubs unlocked.
WARNING this act will result in serious injury or death....
You’re forwarned
Sound familiar...
This rig doesn't have auto lock hubs right?!
Also get it in low range.
Unless something is wrong inside the tcase there's little way the hubs are disengaging the tcase..
No way that makes sense.
Keep digging.
tke395
