I've got a noise coming through the frame, body etc, like a bearing noise but not all the time.
The noise only starts up from 35 - 55 mph.
Open the window and listen seems like I cant hear any noise that way.(I know wind noise outside)
It doesnt do it at lower speeds.
Seems only to do it when its cold.(drivetrain that is)
When I swerve the noise does not change.
Speeding up or slowing down doesn't seem to change the pitch of the noise.
Pushed the clutch in going highway speed, no change.
Stepped on the brake, a little, going highway speed, nothing
Got under it after the noise and felt the joints & hanger bearing and it was fine not hot, rear end was warm, (normal??)
Seems to come from the drivers side rear area,(could be just where I'm sitting)
I've been under the pickup making sure the joints arent loose, greased em seems like it helps for a while, but then it comes back.
Goes away after a few miles, 3-6.
All the fluids are good, rear end, transfer case, trans, changed the trans oil last Sunday.
Any ideas where to look next or what to look for??? Thanks guys, this one is really starting to bother me.
