Teflon Oil line to the turbo . . .
Noiseydiesel
Hillsboro, Ore
So I took the original brass fitting and reinstalled it. Due to the hex outer nature of the fitting and that made it possible to stuff a deep socket onto it for installation. Add a few steel pipe extensions to the top of that and then a 45 degree to angle it away from the turbo.
The orange high temp wrap will go over that and it should live a good long time.
Especially once the turbo blanket shows up.
That 1/4 inch oil line goes up to the 'manifold' on top of the turbo and comes out 1/8 inch on the other side.
Turbo gets a good oil flow and the manifold is a nice restrictor to supply other items, if added at that point.
olsen726
