Well, I'm ready to apply the Tech Line Cermaic coatings CBX to my piston tops.......
They wont sell it to me because I'm not a dealer and it needs to be baked in an oven that isn't used for food!!!
So, they give me 3 places that will apply it for me. Gees, the first and closet place wants $40.00 per piston... The second wants $135.00 for all 8 pistons.....
So I will be getting them back in 7 to 10 days... Then its out to be balanced and finally to assemble it all AGAIN... I sure hope my luck holds out till I'm over 80 should I last that long.....
If not this is for all those that have dun me rong....
I do give them plenty-o-money when I'm in there. I use them for all those parts you loose when your doing something like dash work. When Banks installed my Sidewinder years ago they broke the vacuum manifold found on the firewall. Ford doesn't stock or sell it anymore. So I went to the wrecking yard and found the big Mercurys and Fords have the same item so I bought several. Just look for things on the Ford line and you probably will find they put things in several differant cars and trucks...
