Tech,"Brighter lights" link not working
chillman88
Central NY
Most likely just the headlight relay kit and some Sylvania silverstar bulbs. Bronco graveyard has a plug and play relay harness.
The_Josh_Bear
Western WA
chillman88
Central NY
I have that harness and its SOOOO EASY!!! Works great with new housings off Ebay too. If your housing is faded and yellowed then the harness will only do so much.
Edit: well I have the same harness but for my 89. That one says 92-97 so its OBS.(but oddly enough the website navigation header says 80-96!)
Yeah I put it on mine and it helped, but newer clearer housings made a bigger difference.
Definitely worth the cost for the harness, it helps either way.
lewisstevey7
