T19 Crossmember
hesutton
The Anti-Anderson
Bowling Green, KY
How far off is the E4OD member? Having swapped tranmissions and crossmembers from different trucks/trans on my IDI's, they are all pretty close. I've not had to deal with an E4OD crossmember so I don't know how much trouble it would be to reuse it with the T19.
I've not see those crossmembers linked above used in an IDI before, so I'm no help there.
Heath
junk
Paullina, IA
I built a crossmember, but I have a splitter mounted also. So you could make a crossmember or use one of those.
Check your PM's I may have you covered on a factory crossmember.
justinray
Contributor
Cleveland, Tx
Replied.. Im going to use a ranger o/d, why wouldnt it work with splitter?
junk
Paullina, IA
This is the t-19 crossmember I have. I even have it boxed and sitting in my car. If you want it let me know and i'll get it out UPS.
Thanks,
Jeremy
Bo17
