one of the most annoying side effects of drivetrain mods is the occasional situation where the truck develops a harmonic vibration as it hits a certain speed or RPM. Upon assembly of this truck's drivetrain, the first driveshaft segment was obviously pitched at an angle of greater than 3*. this is suggested by my driveline guy to keep the harmonics to a minimum. One of these angle gauges is critical for the following measurements. In the following pic, you'll see the gauge is "zero'd out" on the base of the lift.
next, you'll see the driveshaft that 10* off .
But since the GV is 3* off, some of the angle can be "subtracted" off the total angle on the first driveshaft segment.
there are two most obvious choices for transmission mounts. The original was the thicker of the two, so I put it back in initially, since I didn't know what to expect. later on this week, when time and energy permits, I will swap in the shorter of the two mounts and see how it does.
the rear segment is sitting at a rather shallow angle but currently in the back of the truck is one complete dually rear end assy, 4 f350 rear spring packs and two f250 D50 spring packs. plus whatever assorted goodies from this project.
well....this concludes this post for the moment, for those who are curious, you can post a max of ten pics via the inline format as you have text inserted.
