T-19 hard to shift when WARM?
vicp21
MI
I don't know how it could be a clutch problem. Even if you don't depress the clutch pedal you should be able to smack it out of gear with a little effort right?
Kizer
Denton, Texas
I'm with you. Unless the clutch is smooth worn out ... I should be able to float the gears and drive around relatively easily (barring: hydraulic, pedal mechanism, fork or TOB failure) ...I think.
Maybe I was just hoping it's the clutch.
The input is much appreciated.
Kizer
Denton, Texas
F1TZ-7548-B
I cannot stress that one enough for guys with a t-19 who are putting in a new clutch
I guess I'm slow. I just realized that you gave me a pn for greasable TOB.
If I had known to look for it I would have searched "parts bin".
Thank you for the info. ... ordered / on the way
steelheadguy
Registered Idiot
Southern Oregon
I was looking at that greasable bearing. It looks way different than the one I took off my truck. So I havent ordered it yet. Where did you order from? Final price?
Kizer
Denton, Texas
Update: ordered and received the clutch kit, MC and hydraulic line. The slave was replaced a few months ago. Before I took ol' girl apart, I decided to change the gear oil one more time. Drained "new" 80w90 and replaced.
PROBLEM SOLVED.
I can't believe it.?
And now I have a clutch on the shelf ... maybe for this
Kizer
Denton, Texas
So it was the oil?
My hypothesis: When I drained the oil, the first time, a significant (adequate) % of the crap in the old oil contaminated critical surfaces in the sycro. mechanisms. Second oil change "washed" it out.
Strictly a hypothesis.
tke395
