rdoimages
After relocating my gp controller/relay and the associated harness, I found I had an engine light on and no reading on the oil pressure gauge. Found that the wire from the sending unit had at some point in the past gotten pinched between the block and the bell housing and when I pulled on the harness the already fragile wire broke. So, thinking to myself "well self, that's no problem, you can just fix the wire with an added length of wire since you moved the harness" so listening to myself, I did just that. Of course, looking around my disaster area of a garage, I couldn't find any wire of the exact same gauge, so I used one size smaller. Of course I still have an engine light and no reading on the gauge. Could the size smaller wire really be the problem ?
Sent from my iPad using Tapatalk
